- Three? Each is maybe 16 max so even 4 would pull only 32 per side max.
Licensed electrician or handy man? - mobeewanExplorer
fcooper wrote:
100 amps available....50 amps per leg x 2 legs...so answer is yes
fcooper is right. You are not thinking about how a 50 amp / 240 Volt system works.
You have 2 120 volt legs with 50 amps available on each leg not 25 amps on each leg. 50 + 50 =100 amps of 120 volt power. - rk911Exploreri've heard of but not seen in person RVs with 100-amp service. connected to a 50-amp post i believe the most a rig like thar could draw would be a bit less than 50-amps else the post CB would trip.
- fcooperExplorer II100 amps available....50 amps per leg x 2 legs...so answer is yes
- Wired properly, BS!
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
