PaoliExplorerMay 12, 2013Pump ProblemThis morning I was pumping the sewer out. Wife turned on a tab inside and the water pump quit and so did the sewer pump. Both at the same time when she opened a tab. Checked all the breakers, nothi...Show More
Old-BiscuitExplorer IIIMay 12, 2013Yep....110V AC power uses circuit breakers12V DC uses fuses (or DC circuit breakers which are resettable fuses, either auto reset or manual reset)Sounds like both pumps are on same DC line......exceeded fuse size with both running at same time.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentWater Pumpfreshwater pump maddening problemwater pump problemsAtwood water heater problemShurflow pump problem UPDATE
