RJsfishin
Nov 01, 2015Explorer
My test results slightly different......
120 v .8 amp fan, after 20 minutes, ran perfectly quiet, but on hi speed, it ran the exact same speed as it normally runs on low speed.
after 20 minutes motor was completely cool, and the 5 ah batt voltage had not changed from a loaded 12.2 volts.
So, even tho it appears that this fan could be run on MSW at a handicapp lower speed w/o damage, it sure wouldn't be advised.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
