peirek wrote:
sidney wrote:
Has any else found that you need to be very careful not to over tighten the sensors? Mine seems to be very sensitive... I've had 2 sensors stop working after towing for a long while as the temperatures increased. I pulled over and loosened the sensor a bit... started driving again and the sensor came back online after about 15 minutes.
Which system are you using? I have not noticed this issue with the TST.
I have a TST 507 system... without the flow thru sensors.
I'm towing a 36' 5er... could it be an intermittent range problem?
