BFL13
Apr 12, 2020Explorer II
naturist wrote:
Your Tracer 4210AN CC allows an input voltage of 100 volts. You can safely put those 3 - 24 volt panels in parallel with no further modifications to your system.
The question really is how much WORK (and money) do you want to put into this system.
No on the volts!!!! That 325w panel will have a Voc (that's what you use for this) more like 46v (will get specs later to confirm exact figure) so 3 x 46 is 138 and that is at 25C. You have to allow some margin for when the voltage goes higher at times too.
https://s3.amazonaws.com/ecodirect_docs/HANWHA/Q.PLUS+L-G4.2+320-345.pdf
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
