dougrainer
Oct 22, 2021Nomad
IF the refer starts working on LP, then no problem. BUT, if it fails to cool correctly on LP but DOES when you plug into 120 volt, then you need the LP gas pressure checked. AS others mentioned, there is NO PILOT FLAME on your model. Just the regular flame. But, if your LP pressure is slightly LOW, then the cooling capacity is diminished. This will manifest in what you state is NOT a roaring flame. But, it is extremely difficult for anybody to just look a a Refer flame and state that the LP pressure is below spec. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
