aftermath
Oct 23, 2021Explorer III
rfloyd99, You have gotten a lot of excellent, and accurate, advice. Opening the valve on your tank can cause many issues.
My take on all of this is, you never had a problem. When you run the fridge on propane it takes some time to cool down. I found that it actually takes longer when on electricity. I listen carefully for the click and can hear the flame ignite. It NEVER roars, and if it did I would turn it off quickly. Something is wrong if you hear this.
Pay attention to the back side, where the access panel is. Keep it as clean as you can. Vacuum out, or blow out the dust and cobwebs if there are any. It doesn't take much to block the flow to the burner.
As long as you see the flame, you are good to go.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
