Gjac
Oct 26, 2021Explorer III
I understand what you mean by a roar I can hear mine also when I turn it on. If you have not cleaned the burner tube in 6 years I would do than first. Not only do rust flakes fall down from the chimney on the tube blocking the slots reducing the flame but very fine rust gets through the slots and will build up inside the tube and will reduce the flame size also. It is very easy to remove and clean and at the same time clean the orifice with alcohol. I vacuum mine out every season.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
