time2roll
Sep 12, 2014Nomad
Desertboy wrote:
(Beauty of 300w is you can use existing main battery connection. No pulling wire.)
Can you go in to a little more detail on that Sir? You have me curious.
Most RVs have #8 or #6 wire from the battery which is plenty for the 30 amps max the inverter will draw. So you can tap on the main battery feed to get 12v power. Then with a small transfer switch connect the 120v power to the circuit of choice. So no pulling 120v wire from the battery compartment to the place of use. Yes you still need to wire it up, just no pulling through walls or compartments.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
