eocamper's avatar
eocamper
Question about Co2 detector
My set up is ALL electric. No propane. I have a CO2 detector in the tt. I'm sure it was installed by the mfg. not knowing the unit would be all electric. My question is. I'm sure it's good to have,but do I really need it? Been thinking about disconnecting it. Any thoughts and suggestions are greatly appreciated.
Unit is a 2015 Grey Wolf 26bhe.
  • Toddupton wrote:
    You do t have propane heat at all?
    No tanks, no propane. My heater is a heat strip mounted to the wall. Have not used it since we just git the tt. Our there tt we used electric heaters. Don't like sleeping with the furnace on. The water heater is electric and no stove/oven. Came with a portable 2 burner hotplate. I usually BBQ and if DW cooks which is usually breakfast, she prefers using an electric skillet.
  • If you have no propane and use no portable gas appliances in the rig and you never keep the engine running on the rig or the tow vehicle (whichever) then you probably do not need it. But if your park near running vehicles as in a rest area for the night etc then you are at a slight increased risk
  • Well it's a CO detector. It may or may not be combined with an LP gas detector. Do you have a generator? And you do have a vehicle engine, and may well park/camp near other engines or generators.
    Why would you want to get rid of it? - it might save your life!
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
