tryingitout's avatar
tryingitout
Question about converter
I have a World Friendship converter, and it seems to be reducing my 12 volt power. I will explain, when plugged into shore power it works fine putting out 13.6. When I unplung and run on battery, I have the problem. I have 2-115 amp hour battery's, reading 12 volts with my tester. When I turn on some lights and the pump runs the battery's stay at 12 volts, but at the converter it is down to 10 volt. The pump won't shut off because it is down to 9 volts. I disconnected the converter from the distribution panel, and it helps considerately the voltage comes back up to 11. I have no problem buying a new converter, if that is the problem. I just don't want to buy one and still have the problem. Any insight into what could be happening?
This is a 2006 living quarter horse trailer that I just bought, I think it spent most of its time plugged into a/c at horse shows
  • Anytime a WFCO converter is involved in a problem, my money goes on the converter as the culprit.
    Just because you see over 13 volts, doesn't mean it is putting out much amperage and a good reason for bad batteries. But your batts may be bad, but probably because of that converter.
    If you replace the converter, and it doesn't really fix the problem, you didn't waste any money, trust me.
  • The battery is 12 volts and the fuse panel is at 9 volts? At the same time?
    If true then you have a high resistance (bad) connection between the battery and fuse panel. But I think the batteries are suspect. Have the batteries been allowed to discharge below 12 volts in storage? (very bad)
  • Artum Snowbird wrote:
    I'm thinking it's your batteries are dead and need replacing. Your converter is doing it's best to charge the batteries when you are plugged in, but as soon as you disconnect the battery voltage drops down to almost nothing.
    A good battery would hold a charge and show you 12.6 volts or more for many hours after you disconnect from shore power.
    X2
  • I'm thinking it's your batteries are dead and need replacing. Your converter is doing it's best to charge the batteries when you are plugged in, but as soon as you disconnect the battery voltage drops down to almost nothing.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
