bmw1999m3's avatar
bmw1999m3
Question about electrical box inside project RV
Hello, I have recently purchased a fixer-upper motorhome (major project, basically torn apart inside, had to rebuild everything) and am nearing completion on the electrical stage. It came with a power distribution box with breakers and fuses. Both the 12VDC and 120VAC circuits connect here. I am just wondering... what is the giant transformer for? It's on the bottom in the attached picture. Also there are what look like resistors near it. Can someone explain if this is for the 120v system and how it affects it? Thanks in advance.
  • Nice, thanks for the link. Yeah I like that box. The one I pulled out is really old, bulky, rusty, and weighs like 30 pounds
  • Thanks Scott, and sorry about the picture size... I scaled it down a bit.
    I am thinking of wiring it up differently than it came originally. Is the transformer necessary if I just use a battery array instead? I'm trying to do away with a lot of old rusty obsolete stuff that came with the RV. I replaced all the lights with LEDs, got rid of 12v fridge, etc. The power demands should be much lower than the original 1983 equipment that was installed in it. I was thinking about just letting the batteries get charged with the alternator, solar panels, and/or a more modern power converter when hooked up to grid or generator to eliminate the bulky stock power box. I totally redesigned the interior and would like a nice compact, lighter distribution box to accommodate it
  • The transformer makes 12V to power those types of items in the RV and charge the battery.
    BTW, you need to limit your pics to 640X480.
    Cheers,
    scott
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
