Gdetrailer
May 20, 2022Explorer III
Lower voltage means the fan motor will turn much, much slower.
Slower fan, more heat buildup in the furnace heat exchanger..
More heat in the exchanger and you can reach over temp cut off which turns off the burner until the temp goes below the trip point.
Slower fan can also mean that the other "safety" can trip which is the fan "sail switch" and that can also trigger burner off.
Slow fan also affects the burner flame directly, the fan motor is double sided, it has a fan on for the inside air and a fan on the outside air for the burner (inducer fan). The inducer fan helps move the heat and combustion byproducts through the heat exchanger..
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
