tfirma's avatar
tfirma
Question about inverter use and power draw on batteries
I will apologize right off the bat - this is both probably a newbie question - and also a bit convoluted.
So my brand new 1995 Lance has two 12v outlets... I was trying to run a 150W inverter or a 300W inverter - and having all sorts of trouble just running a macbook off the inverter (85W, I believe) I got about 5 different ideas on the issue (everything from "the wiring isn't outfitted for anything significant" to "it should all work fine" which was right from Lance themselves). Finally, the dealership did call me and said the one receptacle is "charging only" - which apparently means it doesn't have the capacity to run ANYTHING significant besides the smallest of electronics. So I focused on the other receptacle for the TV. Lo and behold, I had more luck with that. I COULD power the Laptop...but something strange is happening for which I'd love to get an explanation....
I've got two 12V batteries wired in parallel and a 160W solar package. The solar charge controller reads 100% (which I thought was the level of battery power remaining?) - but then, of course, there is also the meter reading panel for the tank levels, and battery power on the kitchen wall. Electric power has been at 100% - since I really haven't used too much power for too long...just testing things out and using some lights and occasionally the heat. (and I'm not plugged into shore power) HOWEVER - when I ran my notebook - I noticed both the reading on the solar controller went down VERY quickly (within just a few minutes, it was down to 81) AND the meter for battery strength went down to 3/4 and then even 1/4. I assumed that the drain on the batteries was just TREMENDOUS for the levels to go down so quickly. That would surprise me - I realize running off the batteries will drain them - but I can't believe it's THAT fast? But here is the stranger part. I turned off the inverter...and within about 5 minutes... I was back up to 100% on the charge controller AND on the battery meter level reading. I can't imagine the solar could help out that much that quickly - because it was raining all day and not a hint of the sun was out during all of this. I also can't imagine the drain on the batteries could be THAT substantial and so rapid for only using a 150W inverter for about 3 minutes..... But then, since the levels seemed to go right back to 100%, I'm wondering if something else is going on -- or those readings maybe mean something else?
I tried my best to describe the scenario. So the two questions are :
- Is the reading on the solar charge controller (GoPower) the actual percentage of battery power left, or something else related to the panels?
- Is it possible that just using my laptop on a 150W inverter for less than 5 minutes would drop that percentage to 81% AND the battery meter reading to almost 1/3?
- Why would both levels on both meters go right back up to 100% after about a minute of unplugging the inverter?
Thank you so much in advance!
Tom
  • I agree with enblethen, you have wiring inadequacies more than anything. It may be something as simple as a poor ground connection at the battery, and cleaning it up would help things. Connecting your inverter directly to the battery would also work well, but be inconvenient. A more permanent solution with direct wire connections would be ideal.
    Your meters are reading voltage, but not necessarily the voltage of the battery (this is particularly true for the one with the tank level meters). It's quite possible that they're also seeing the voltage drop from the inverter's current consumption. The battery voltage itself is probably rather higher than it suggests while under load.
    You might also want to check the condition of your batteries if you have not done so yet.
  • First thing I'd do is hard wire the inverter to the battery bank, or at least to the 12v distribution center. Then see if voltage stays up.
    If the circuit that you have the inv on, happens to be the same one your meters are on, that mite explain it all.
    Always hard wire the inverter,...just to get it out of the problem.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 04, 2025
