naturist
Jun 06, 2021Nomad II
You can only get full rated output for an hour on either side of true noon, and only under perfectly clear sky and then only if the panels are perfectly aimed at the sun. Anything else will cut output slightly. Also, lithium iron phosphate batteries typically require the charge controller to output 14.4 to 14.6 volts peak to charge fully. This calls for reprogramming from the lead acid program that is the usual default.
