StirCrazy
Jul 23, 2021Moderator
the only way your going to get better is by moving to a MPPT. your figting tow things here a 12V pannel and a PWM controler. if you take your panel and devide it by 17V that will give you your potential max output with a PWM controler on a 12V pannel as they are in efficent in the conversion. you can improve that a bit with a MPPT controler, but realy from a 120V suitcase pannel there are so many other factors that will play in. shading, wire size and lenght, conection to the battery and so on..
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
