SoundGuy
Feb 01, 2018Explorer
Seems no one has pointed out the obvious - why you would want to run your water heater on both modes simultaneously. Answer - quicker recovery, so your wife doesn't yell at you halfway through a shower. :W
Assuming your Suburban hasn't been installed with an switch inside the trailer that can be used to turn the electric mode on / off just add your own as I did with our previous K-Z Spree. I used a paddle switch with a built in light which would indicate when the water heater's electric heating element was on ... much easier than running outside.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
