BB_TX
Feb 01, 2018Nomad
If the weather is warm/hot I typically run mine on electric only. But if temps are cold (meaning the incoming water is cold) I run mine on both electric and propane for the better recovery rate. I never run propane only. I have forgotten to turn it off before going to bed and the propane WH kicking on at 2 am will wake you up. Electric will keep the tank hot enough the propane will not kick on until you start running the hot water.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
