2oldman
Jun 05, 2020Explorer II
Sounds like only one panel is working. The controller will dial back the charge rate as needed. I don't know if your controller shows what's coming in from the panels.. that would be a clue.
I've had two panels fail in 15 years. They show burnt spots, black or brown, on the front of the panel. They're the aluminum ribbons that connect the cells together. They get hot, so you want want to check for hot spots.
You can check each panel with a voltmeter, or, temporarily wire in series to see if the voltage doubles.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
