KendallP's avatar
KendallP
Question for Battery & Solar Gurus - Daily Charge Setting
Hey gang,
This would be one for you solar experts and certainly ol' Mex...
My father still has his 8 Surrette L16 equivalents in the home, off-grid system. I think they've got a few years on 'em now. He uses 'em pretty hard and I'm a bit concerned that they're not getting the care they deserve, i.e. relying too much on solar and not much generator unless they inverters shut down.
I've been counseling with him to figure on a little more generator each morning with the PV to do less Bulk, more Absorption and more of a topping job each day. This with an occasional equalization for maintenance, of course. However, the goal is to require fewer controlled overcharges in hopes of fewer average man-hours to maintain the batteries.
Weather has been clear and cold lately. Perfect conditions. Nevada. Gotta' love the high desert when you're off grid, eh?
May not need the generator 'til the clouds roll in again. He just texted me that the system is doing 12.5A at 59.8V and the display on the Outback MX60 MPPT Controller reads "ABSORBING," which sounds right. Peak voltage setting must be 60 or so. He can hear bubbles, which also sounds right.
All that said... the question is pretty simple...
What's a good peak voltage setting (maybe one for winter and one for summer?) for a mechanically inclined, but busy man who isn't as obsessive as we freaks here on the boards?
I've been suggesting 62 (15.5 equivalent.) Seems a good balance between too low vs. frying plates too hard on a fairly regular basis.
And you say?
  • Snowman9000 wrote:
    Rolls Surrette manual
    Flooded instructions on page 9.
    Just found that myself too. Thanks!
    The settings with temperature into account are much more to my liking. Looks like he's good at 60 through the winter.
    However, I was wondering if folks had more "custom" settings they're comfortable with. We're talking PV here. The batteries are up and down everyday and they would likely not often sit on 60V for long. So if you gave them more of a mild overcharge whenever the system provides, would that be OK and possibly conducive to even greater life?
    I'm sure it would be better to go by this guideline and include a regular equalization schedule, but sans that...
  • Almot's avatar
    Almot
    Explorer III
    Not sure about "peak voltage". If you mean Absorb voltage - i.e. when it stops rising and switches to Float - this has to be set according to the particular battery manual, and nothing else. Doesn't matter what solar and what controller you are using.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
