wa8yxm
Jan 21, 2015Explorer III
If you are designing an LED power supply then I will assume it is a DC supply, Capacitance should not be an issue less you are using a retangle wave dimmer at fairly high frequency. I'd go with mica washers and artic Silver. (but them I am old school) Googled Sil-Pad, looks like it is a superior replacement for the Mica Washer.
Capacitance: Any time you put two slabs of metal close to each other with an inslator (Even air) between them,, You make a Capacitor, It does not matter what heat conductive stuff you put there, Artic Silver or something else, you have a Capacitor, No way around it.
As the plates come closer the capacitance incresases, as the smaller one gets bigger, Capacitance increases, Doubling up on the sil pads, Decreases it.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
