gotsmart
Jul 25, 2013Explorer
I don't have a tank rinser installed on the black tank, nor do I wand it from the toilet. My dump valves are configured so that the grey tank back flushes the black tank. This is what I do when it is time to dump the tanks:
1. top off both tanks.
2. dump the black tank - leave the valve open when it is finished
3. dump the grey tank - it back flushes the black tank as it dumps
4. close both tank valves.
5. repeat steps 1 through 4.
6. Add 3 to 4 gallons of water to each tank - to keep the seals wet and the bottoms of each tank wet as well.
I've been known to repeat steps 1 through 4 a second time.
About once every month and a half or so, I'll notice the odor in the black tank is rather strong - after dumping and rinsing twice. I'll fill the black tank with 5 gallons or so of water, add 8 ounces of Clorox Bleach, then top off the tank. Then I top off the grey tank as well - then let the black tank soak for 2 to 4 hours and let the bleach go to work. I call this "soak time". Then I repeat steps 2, 3, 4, and 6 - and I'm good to go.
After dumping and rinsing (or dumping, rinsing, bleaching, and rinsing) I add 2 cap fulls of Liquid Tide laundry soap to the black tank. My bathroom sink drains into the black tank - so I dilute the 2 cap fulls into a sink full of water before letting it go into the tank (otherwise I'd dilute it into a pail of water and then pour the pail down the toilet). Whether or not it helps to keep stuff from sticking to the walls of the black tank - I don't know, but doing so doesn't hurt anything.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
