pianotuna
Sep 11, 2015Nomad III
Hi At 125 amps of charge the power factor corrected magnum only draws 15 amps @ 120 volts or 1800 watts. I suppose if the generator is not 'warmed up' it might overload.
The hybrid Magnum will charge and invert at the same time. It goes into 'load support' mode so any demands above the shore power input setting will be covered by the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
