Golden_HVAC
Oct 03, 2015Explorer
CA Traveler wrote:
" Is it possible your inverter is truly whole house and was feeding your converter charger?"
Good question - The Magnum is a charger/inverter and it won't charge and invert at the same time. However, is your original rig charger turned off or better yet disabled?
I checked the RV with a DC amp meter. The meter reads only 7 amps DC output while the inverter is running. If the factory converter had still been plugged in, then a load over 40 amps would be on the inverter. SO I do not suspect the factory converter is still plugged in.
The OP bought the recommended DC clamp on amp meter, and will take it camping someday. I showed him how to use it, and he will go to a full hookup campground, charge the battery, and then unplug to run the CPAP on battery power. He can then measure the CPAP battery draw, and see how well his batteries last overnight.
His 500 watt solar system looks to be a top notch install, with huge wires going to 60 amp DC disconnects, a very professional installation. The RV was parked in covered storage, and the solar would not work, so I did not see if it was working.
I will be out of town the next weekend, and could not look at it until after the 15th at the soonest. I will check back with him to see if the coast campout worked well or not. My suggestion if the amp figures are correct, and still the battery goes dead after 7 hours dry camping, that he might need another CPAP connection (such as a DC plug for his DC CPAP (it has 12 VDC input but he is using a 120 volt transformer and step down converter for it).
Anyway I was patient with him, and I think he has the knowledge to figure it out on his own from this point on, but I am willing to give it a go to help out if I can.
Sorry to hear others became frustrated. He is trying in earnest to figure this out. I think that he also became frustrated with people asking 'try this - Try that, you did not answer is the factory converter still in place'.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
