Bobbo's avatar
Bobbo
Explorer II
May 04, 2018
Question for MEXICOWANDERER
Mex, my Airstream trailer came with no illuminated switches where you can tell if the switch is turned on at a glance from a distance. I have added illuminated switches to 3 locations, but there is another switch that I want an illuminated indicator for. However, there is a problem.
The remaining switch is not just a pop-in switch. It is connected to a printed circuit board and has a dimmer slider. It has 3 wires coming to it, a fused hot wire, a load wire to outside lights, and a ground wire.
I am not wanting to use the load wire to outside lights to power the indicator LED because if I dim the outside lights with the dimmer slider, it will also dim the LED indicator light. I want the indicator light full brightness regardless of the dimming slider.
Have you any ideas?
Thanks
Bobbo
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
