Fire_Instructor's avatar
May 19, 2013
Question for the Battery Experts
I have a pair of 6v CG batteries that I use to power the rolling home. Sam's Club, Ever-Ready's (220Ah). They will reach 3 full seasons about mid-season this year. They work flawlessly, and seem again this year, to be fine (I disconnect them with a full charge and store them in the basement of the stationary home for the winter every year).
I want to add a second pair of batteries, to take better advantage of my solar array, and to be able to run the microwave a bit more. Sam's has a newer version of the same battery, which will give me 240Ah additional capacity. I also have a several year old 12v gel-cell that came out of my parents old 5'er. It's got a full charge, but has been used for practically NOTHING for a number of years, 7 or 8 to be exact.
All three of the trips that we already have booked for this season will be boon-docking/dry-camping (GS/CW RV Rally in Syracuse, 10 days on Assateague Island, and 5 days at Dover International Speedway). Likely the fourth will as well, at a state park here in NYS. While we don't exclusively dry camp, a large percentage, many years the vast majority of our trips are without hook-ups.
So here are my options, as I see them:
1) Do nothing until the two existing batteries go bad. With the "smart charger" built into the Rogue controller, that could take a couple more years.
2) Add two new batteries to the bank.
3) Add the older gel-cell to the bank, then replace the gel-cell and the two GC batteries when something finally fails.
4) Buy 4 new GC batteries. (The "cheap' inside of me coils at the thought!!!!)
So what do the experts think?
Thanks for any guidance / suggestions!
  • No problem as long as you have solar or converter keeping them charged every day when stored. Worst case you are out $180 at Costco over the next year or two. I think the set will last much longer than that. In the mean time you can use all that extra power to enjoy camping the way you want to.
  • X2 smk. Given the SG on my present batts, if I wanted to add more, I wouldn't have a problem with it (mine are 3 years old also). I don't think there will be an issue adding two more batts to your present one's.
  • Interesting. Two of the regular posters whose opinion I value greatly, smkettner and pianotuna, give different advice. Then Mena661 (another whose opinions I trust) backs up smkettner. Maybe mexwanderer will chip in and tie it up again. :h
  • The variation in opinions seems to be around the compromise of adding 2 new golf cart batteries to the 2 old ones. You could shorten the life of the new ones. Some think it's worth it for the extra capacity you gain, others say not. It's not really a technical question, it is a risk for the money question.
    Personally I would decide based on the condition of the existing batteries. If the specific gravity fully charged is near what it was when new, I'd do it and compromise the life of the new batteries a bit. If the old batteries show signs of getting old (low SG across the board that is uncorrectable, cloudy or smokey electrolyte, won't hold their voltage, won't pass a load test) then I would go for 4 new ones, or use just the 2 until they die.
    You really do have the option too of charging different type or health batteries separately and drawing them down together. It is more work but it can get you that added capacity if you only need it occasionally.
    Jim
  • Hi,
    If you add more, then bank switching would be the "safe" bet. But since you have 300 watts of solar, my best guess is that the six volt twins start every trip bursting full, and the same thing happens pretty much every day during holidays.
    There is always the generator, or alternator as a "back stop".
    I believe that way back when the solar system was being planned I suggested more battery capacity. At least there is enough solar to adequately recharge a doubled up bank. It is rarely wrong to have too much capacity.
    I'm semi full timing and am in the middle of a three day rain. It is cold enough that I'm running the furnace. It is a comfort to me to have lots of battery capacity.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    A lot of folks seem to feel that all batteries in a bank must be IDENTICAL.. I am not convinced..
    You need to divide your thinking a bit, First, as I just posted to someone else think of each pair of six volt batteries as one 12 volt,, We will call the two pair old and new.. Pair only the two old ones together
    {old}-{old}
    and the new ones likewise {new}-{New}
    You can not put 'em in parallel.
    {old}-{old}
    {new}-{new}
    now problem
    now due to differences in age it is a fact that one pair will tend to supply a bit more current, and likewise accept (under charge) a bit more, but the state of charge on both pairs will be identical for all time after the first discharge/charge cycle.
    As for the gel cell.. (Are you sure it's a gel and not an AGM)
    Gel's do not play nice with other types.. I'd avoid them completly
    AGM's (Which are often mistekan for GEL) do play nice with other types, but .... I'd still keep it around as an emergency battry. Charge it with a battery tender or battery minder, put it in a wooden box with handle and a pair of jumper cables and use it for those OH "Black Tank Contents"! situations.
  • Not an expert, just an opinion.
    If you feel you want, or need, the additional storage capacity, then you should have it.
    If you plan to keep your rig for awhile, I suggest that you sell (or give away) your existing batteries and start with four new ones. This way, you know that you won't be replacing older batteries every 3 or 4 years.
    Alternatively, if you want to do a science experiment for the benefit of the rest of us, mix the batteries and let us know in a few years how it turns out.
    Good luck with your decision and have a great camping season,
    Steve
  • Well, Folks, I did it, and did it right! Four brand-new Duracell 6v GC batteries installed this morning. New cables from The Pacer Group.
    Extended the battery terminal up 1", so that the battery caps could be more easily removed - all three caps on each battery come off as a single unit, not individually. Got 7/8 long "nuts" (used for joining two threaded rods) and this lifted the cables sufficiently for the caps to easily clear!
    Everything all connected and tested! I now have 460Ah of capacity, which will run the Margarita maker for HOURS!!!!!
  • Nice! I envy all those amp hours.
    Have you started charging them? What were their starting voltages? Do you have a hydrometer?
    Jim
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
