enblethen
Jan 28, 2015Nomad
Not sure what your plan is.
It sounds like you are going to want to set up so the receptacle on the outside can feed the house during a power outage and then feed the RV during normal configuration.
This would require two receptacles on the out side of the house. One male and on female.
Then a transfer switch somewhere in the system to disconnect the genset female receptacle from the power coming from the utility.
This could be a transfer switch unit from a electrical supply.
It would require some serious design and installation procedures.
