wa8yxm
Jan 29, 2015Explorer III
Bull Rider wrote:
Consider if you will also want a 120 volt drop at the 50 amp RV panel. That might require an extra wire. I don't think you can pull a 120 volt leg off of the dedicated 220 feeds. But I'm not certain of this, but it's something that would be easy to do if it's part of the plan.
Bull he stated the 50 amp outlet would be a 4 wire feed, SO he has already considered that and done the right thing
L-1, L-2 (120 volts each with respect to neutral) Neutral and Safety ground are the 4 wires.. He is doing it properly at least there.
As for the O/P's questions however,,, I'm fairly good with electrical stuff, but this is one level past what I'm comfortable with. I will only give this advice,, GO BIGGER, do not put in the minimum size but go at least one size bigger, makes the wires easier to pull, epically if "Stuff" happens.
