dalej's avatar
dalej
question for the solar gurus
Trailer is stored and not being used at present.
The solar system is active and keeping the batteries charged up. Every morning it goes into 14.4 volts absorb and later 13.7 float.
The batteries are deep cycle AGM.
Do you think this might be causing any problems or decreasing the life of the batteries?
  • You're charge controller is doing exactly as it should.
    It will charge at 14.4 until it sees the current flow drop to a minimum amount and then work it's way to float.
    Richard
  • How long does the controller hold 14.4 before dropping to float?
    What are the charging specs?
    Have you turned off any automatic equalization?
    I assume no temperature compensation?
    Yes could be a bit on the high side for TX summer. Probably fine in winter. AGM actually has a very slow self discharge. You could fully disconnect the batteries after a week and just let them sit 4 to 6 months. Always disconnect the solar panels from the controller first if disconnecting the controller from the battery.
    Possibly you could upgrade the controller to have fully adjustable settings. Not sure this would be worth it.
  • If the battery is fully charged and stays that way, blasting the battery at 14 plus volts could shorten the battery life. Charging should stop whenever the charging amps drops to less than 0.5% of the AH rating. For example charging should be discontinued for a 100 AH battery when the charge amps drops below 0.5 amps. Many solar chargers are not capable of making this determination. Most will automatically hold the 14.3 charging voltage for a couple of hours even if the battery is fully charged and the amps drops towards zero.
    There is a reason float voltages are set at about 13.3 v.
  • I am not a guru, but if you don't mind a non-guru reply...
    It's perfectly normal. Every night your solar system shuts down, while parasitic draws on the RV continue to use some power and use some battery amps. Every morning your solar system wakes up, senses that lower battery level, and goes into boost mode, then later drops to float mode.
  • It depends on how LONG it stays at 14.4.....mostly.
    It is probably designed that way on purpose.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 27, 2025
