j-d
Dec 14, 2014Explorer II
On the Dinghy Towing Forum, we're seeing that Ford recommends removing the "+" battery cable when towing several of their recent models behind a motor home.
Ford seems to have tried to standardize its systems beginning 1990's, So, I find it a little hard to believe that a disconnect will cause such grief.
A "memory saver" (like the 9V battery kits mentioned above clearly will NOT solve the problem of the battery running down. If a phantom load is running a starting battery down, a 9V won't last more than a few minutes.
Interestingly, some manufacturers recommend AGAINST a memory saver. So let me say this and hide behind a rock:
WHAT does the Owner Manual Say? I'd see if there was any comment in Maintenance, Battery, Towing, and Recreational Towing...
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
