theoldwizard1
Sep 27, 2020Explorer II
dockmasterdave wrote:
Is it possible a cell went bad or a battery went bad and caused overcharging ? If so , why did only 1 battery overcharge ?
You will never know why that one battery took a dump.
Personally, I do NOT believe in leaving lead acid battery connected to a charging source 24/7 weeks/months at a time. If possible, wire in a cheap mechanical lamp timer and only charge for about 4-6 hours/day. You battery will last longer !
Whey so negative on a pair of 6V golf carts batteries ? They are typically cheaper than a pair marine/RV 12V and usually last longer.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
