phemens's avatar
phemens
Question on changing leaf springs on 5'er
Hi,
I will be changing out the flat leaf springs on my 2012 5th wheel on all 4 wheels. Was wondering if there is any advantage to doing it by axle (i.e. both wheels on one axle, then both on other) vs. just doing one side at a time (both wheels on one side, then the other). 2nd way would reduce some of the setup time I guess.
Thanks in advance!
  • Both on one axle. You will need to lower and raise it to change out the spring, then align it to the centering bolt.
    While you are at it its a good time to replace shackles, bolts amd bushings.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
