valhalla360
Oct 02, 2020Navigator
Depends if the charger really tries to put out 80amps. If not much else is running, should be OK. If you can scale it back to a lower output, no problem.
If you find it is having a problem, you could pick up a cheap 20amp automotive battery charger and do it manually if it's only rare occasions.
One issue with an 80amp charger is your battery bank may not be able to absorb 80amps even fully discharged and assuming lead-acid batteries, no where close once you get about 80% charged.
100w solar will likely be marginal for much more than a day or two of camping...especially if you are running other items.
