ajriding
Oct 03, 2020Explorer II
When you say, 1-2 times per year, what is a time? a few days at a time, weeks? one day?
I think you are set with what you have for just the rare instance. Just run the generator that you select and burn whatver gas you burn.
If you were going to try to boondock more often, then the fridge is killing your set-up. That would be the thing to replace first rather than trying to boost the system to power the wrong fridge for boondocking.
But for always being plugged in to shoreline then the house fridge is fine, and cheaper than an RV fridge usually.
The 2200 in eco mode will idle down when no load is on it, but if the charger is asking for power the gen will idle up as much as is needed to provide power, it will not idle when power is demanded.
Happy trails
Happy trails
