pianotuna
Oct 05, 2020Nomad III
ajriding wrote:
time to roll, 100 is plenty for a propane fridge. Almost nobody will boondock with residential electric appliances. You could probably use a few Duracell C or D batteries to run a propane fridge.
Propane packs more power than a battery ever will. Gasoline packs a lot of power, but is not efficient way to run a propane fridge on 120v. The propane is just a little candle flame, and that is all that is needed to have a fridge.
The parasitic loads in my RV amount to 35 amp-hours per day @ 12.6 volts. There is NO way a single 100 watt panel is going to do that sort of output, unless it is May through Oct with a tilt. Even then it would need to be pretty much perfect solar conditions.
Do a proper energy audit when designing a system instead of guesstimating.
Yours Truly, Nemo.
