outwestbound
Sep 05, 2017Explorer
pianotuna wrote:
outboundwest,
I would change to the flooded settings. Do you know how long the BZ will stay at the various stages?
I had a switch added to my Blue Sky controller that allows me to flip one of the dip switches without pulling the case apart. I'll sometimes use that setting late or early in the day to get the voltage up.
Your system is working ok--but I think you might garner another 10 to 15 amps by changing to a better quality MPPT controller. I'd suggest a single 80 amp unit be used.
The Magnum PT-100 has some quirks. To get to the 100 amp rating, input voltage may need to be 72 volts or higher.
Thanks so much Yes, the manual is here: http://nebula.wsimg.com/cb072ae482f8e0e9544e6469c9ae5b70?AccessKeyId=F8EC79241F00CCD2742B&disposition=0&alloworigin=1
and the answer to your question is, from the manual:
Flooded
bulk - no amount shown; 14.4Vdc
absorb - 2 hours; 14.4Vdc
float - none shown; 13.7Vdc
equalization voltage @ 29 days; 2 hours; 14.9Vdc
VRLA
bulk - 2 hours; 14.00Vdc
absorb - no amount shown; 14.0Vdc
float - no amount shown; 13.7Vdc
Note: No equalization is defaulted to in this VRLA profile. Manual says the dip switch for flooded profile may be manually thrown to equalize for 2 hours, then it resumes float in VRLA profile mode.
I'm a finance/ economics guy, so I've had lots of math and I get this stuff pretty much, when I focus on it, but I just don't consider it a hobby, so I forget the technical stuff rapidly. I recall in January 2016 being frustrated trying to size the controller, because folks selling equipment would not be strait forward, in my opinion, which may have been wrong.
My system was installed April 2016, but I'm really only getting around to using it in the last few months.
I wanted redundant capacity to add 2 more 160 watt panels, which would take me from 960 watts now to 1,280 watts. I bought AM Solar's tiltable panel brackes also, but have never tilted. Anyway, I was looking at the Outback FM80-150VDC MPPT, the Magnum (which I figured might make sense since I got the Magnum 3012 hybrid inverter/charger, but was brand new and unproven), the MidNite Solar Classic Lite 150 MPPT Charge Controller, which I think has been discontinued, and pairing 2 Morningstar TS-MPPT-60. I suspect going back to the market today will yield better alternatives.
At 8 panels, that 18.5 x 8 = 148Vdc at max from both 4 panel arrays into the controller or controllers, and 69.2 amps per the PV panel labels at 8.65 per. I'm wired from the roof in (2) 3 panel serial arrays now, so I'd planned to add 1 panel, if needed, to each array. Splitting the panels made sense in case I get shade, bird poop or whatever, plus to have redundancy. When these BZ 50 amp controllers were offered to me, the 100amps looked good so I punted because I was out of time due to family matters.
Because MPPT's require high voltage, I do not know if it's better to run a single controller near it's max capacity, or get two controllers running at lower capacity. I say this from a safety perspective, because I don't like putting avoidable stress on equipment.
If I bag these BZ controllers this winter, do you have an opinion of how to configure the panel inputs and what controller(s) make sense?
If I use a single 80 amp, buy some calcualtions, 960watts/12 is 80amps, would the single 80 amp controller be at it's max with no room to grow? Even ignoring the consideration to add 2 more panels, is operating at max ok? What I don't know is the efficiency loss parameters, which would reduce the load on the controller.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
