outwestbound
Sep 05, 2017Explorer
checked settings. max charge set at 80%, so that's good. the indication of full is set to display "float charging". set points on the charger appear to match batt specs.
it's floating at 3amps going in, so looks full!
thanks for indulging the creep in this post. I'll read up on this stuff and write up a diagram and spec sheet on what I have. then I'll pay a consultant this winter to help me answer whether a better controller and/or generator setup will make sense. I'll also know more after using the stuff a couple more months.
you all have been very helpful. thanks so much
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
