wa8yxm
Jan 29, 2020Explorer III
You said a very bad word "Backfeed"
That translates to "I wish to suicide"
You do not backfeed.. Now depending on the RV you may be able to feed in via the main power feed (Plug the rig into the inverter) But the usual approved method is
Shore power----Main breaker box--30 amp to 2000-3000 watt inverter/charger with pass through
Inverter/charger----Sub Panel---TV, Microwave. GFCI and other loads to be powered by the inverter.. NOTE the absence of air conditioner, water heater and fridge.
