pianotuna
Jan 30, 2020Nomad III
2oldman,
Are you saying you wish to run the RV as an uninterruptible power supply?
In fact, because I do have an inverter/charger that does load support, that is how my unit could be run.
It also means that if running on the generator, and fuel is needed I can continue powering the RV.
I use a patch panel approach for those times when shore power "hates" the Magnum (gfci some don't like Magnum).
My apologies as this is off the topic which is back feeding--which any thinking person would agree is a lousy and dangerous practice.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
