Ductape_Dave's avatar
Ductape_Dave
Question on Number of Solar Panels
I have a 24'stationary travel trailer that I want to install solar on. I plan on using 2 GC-2 batteries (230ah)in series to provide 12 volts with 230 AH, which I know only 40-50% of that is usable. Being up against a mountain I do not receive direct sunlight from November to Mid-March so I wanted to know which kit would be better to install. I have the option to install either a 300 watt kit (3 panels) or a 400 watt kit (4 panels), but wasn't sure if the 400 watt kit would be overkill or be better for the indirect sunlight months. My average use is about 75-90 amp hours per day.
Thanks in advance!
Dave
  • Almot's avatar
    Almot
    Explorer III
    Don't mount them flat. They should be tilted at least 4-5 degrees to shed water and snow. Higher tilt, like 30-45 degrees "could" help with output, but under gray skies and in the mountain shadow this won't help much, and will create more wind loads. Reflection from snow is an interesting idea, but... New Jersey isn't exactly Alaska, and with weather globally screwed up there might be no snow at all.
  • Since your trailer is basically being used as a cabin. Why not build a ground mount where the sun is all year.
  • Almot's avatar
    Almot
    Explorer III
    He said it has to be moved 500ft away to clear the shadow.
    As a maintenance charging, there is a good chance that 400W will work in the shade. People telling that "solar panels don't work in the shade" don't understand the physics. Full soft shade - when all the panel is in the shade but it's not pitch dark either - is better than partial hard shade. The output (in the former scenario) will drop proportionally to the amount of light that panel is getting. If on a cloudy day in winter behind the mountain it is (for example) 20 times darker than in direct sunshine in summer, then the current will be 20 times less, ex. 1A at noon instead of 20. Plus, shorter daylight.
  • Ductape Dave wrote:
    I forgot to add that I also have a Yamaha 3000iseb generator so charging them would not be a problem during the winter months when they come up short. I don't go too often in the winter and usually just for long weekends.
    Just thought the 400 watts(over the 300 watts) would put out an extra amp or so to keep the batteries maintained when I am not there.
    I am right up against the side of a mountain and would have to go out 500 feet to get sun, but it returns on my side from mid-March to mid-November.
    I think most of us were assuming you wanted the 400W of shaded solar panels to maintain your battery while camping in the RV. If all you want is a maintenance charge to keep the battery up with very little current draw being done during the Winter months....and you are not using the RV .... then yes, I would expect 400W of panels in full shade but exposed to the sky would get enough light to at least maintain your batteries. Even one amp or two would probably be sufficient.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
