mrad's avatar
mrad
Explorer II
Jun 03, 2021
Question on Running Onan onboard Gen on hot days
Would it be advised on hot days (85+) to leave the door open when running the generator to help keep it a bit cooler?
Also, when traveling in hot weather, does anyone run their onboard gen so they can run their AC's? I don't know that it sounds like a good idea, but wanted to see if it is a common practice or not?
  • My experience, 100 plus degree day, ran gen on the road for AC. About 8hs driving.
    Pulled into CG, thing vapor locked. Was fine in a few hours.
    So yeah I think you can get them hot enough to vapor lock
  • If the generator is installed properly, there's no need to leave the door open. If you're referring to a door or panel on the generator itself (as opposed to one on the RV to get at the generator), having it open or removed will often lessen the cooling efficiency of the generator by allowing cooling air to escape rather than flow over the hot bits to cool them down.
    Many people run the generator while on the road, and it's not really a safety hazard or otherwise a bad idea. You do need to shut it off (along with the main engine) when refueling, of course.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 27, 2025
