djousma
May 17, 2018Explorer
dpgllg wrote:
Hello,
I have the Nautilus water management system and I understand how to set the levers to sanitize and it will pull the bleach/water mixture into the fresh water tank.
My question is I have a 60 gallon tank which would be 12 5 gallon buckets. Can I add ALL the bleach to one or two buckets suck that in and then fill the fresh water tank as I normally would? Would the concentration of bleach damage anything?
Thanks for your help?
Dave
Yes. I add the 2 cups of bleach to a 5 gallon water jug that is filled the rest of the water with water, and siphon that in. then I hook up the hose, and powerfill the fresh the rest of the way. And finally, turn on the water pump, and run the bleach water through all the fixtures.
