dpgllg's avatar
dpgllg
question on sanitizing water system adding bleach tank
Hello,
I have the Nautilus water management system and I understand how to set the levers to sanitize and it will pull the bleach/water mixture into the fresh water tank.
My question is I have a 60 gallon tank which would be 12 5 gallon buckets. Can I add ALL the bleach to one or two buckets suck that in and then fill the fresh water tank as I normally would? Would the concentration of bleach damage anything?
Thanks for your help?
Dave
  • Put 20 gal of water in the system then add bleach and then hook to city water for the balance if you have access. I would not put it in first in a dry system, it is pretty harsh stuff.
