time2roll
Dec 13, 2014Nomad
Double check, then triple check the polarity and make the battery connection.
Check the instructions but I believe you should connect the battery side first then connect the panels to the controller. Controller may have issues if you disconnect the battery before you disconnect the panels. May need to be careful of using the switch OFF position but again check the instructions.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
