BFL13
Dec 13, 2014Explorer II
CA Traveler wrote:
OK, If the controller doesn't like a panel only connection what happens if the fuse to the battery blows?
That stopped the controller-battery pos wire from becoming the fuse and melting at the controller terminal, so the controller is toast anyway?
The OP is ok at 14.8v when connecting the 12/24 controller (no array connected yet) ISTR if it sees under 18v it will decide it is on a 12v battery and if over 18v it will decide it is on a 24v battery. so at 15v it will go 12v as desired.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
