CA_Traveler
Dec 14, 2014Explorer III
Johnny G1 wrote:The MS MPPT 60 manual says you "must" for one reason.
Why do people keep insisting that there should be a fuse between controller and battery???? Mine has had no problem in 12 yrs with a C40 controller and the only fuse is between panels and controller.
For maintenance I have a switchable CB on the + battery cable and a 2 pole disconnect for the high voltage panels. This was also a consideration for covered storage to eliminate all controller draws.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
