BFL13
Dec 14, 2014Explorer II
With four 6s you could have approx 1.0v initial drop when drawing 100amps with the inverter. Then it will slowly fall as the load runs. That means to stay above 11.0v inverter alarm, you need the batts at 12.1 to start with, which is 50% with Trojans.
That is important, so you can use the toaster and kettle in the early morning on the day you will be recharging the batts. :)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
