BFL13
Dec 14, 2014Explorer II
rjsurfer wrote:
The batteries were topped off when I started this test. They were floating 13+v.
Ron W.
A single set of #4 is not enough for drawing over 100amps. You can double them up (two pos and two neg) or get single lengths of fatter wire. That should get your initial voltage drop when drawing 100amps to 1.0v or less.
Check the wiring spec for that 2000w inverter for drawing its full rated load.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
