MrWizard
Oct 12, 2018Moderator
the auto OFF converter part, means doing some rewiring and a sub-panel
if you can remember to turn off the converter circuit breaker
the switching between the inverter and the generator can be done by
by DIY build
PUT a TS switch in a weather proof box (plastic ammo can?)
need too male plugs, one female outlet, and right size cord
female outlet is for the RV shore cord
(2) male cord ends, one to connect inverter, one to connect generator
default is for inverter to be connected, switches to generator when genny is started
by DIY build
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
