theoldwizard1
Oct 13, 2018Explorer II
phemens wrote:
Getting older and lazier, there must be an easier way, right?
There is, but it won't be cheap !
Replace what you have with a combination inverter/charger/transfer switch like a Samlex Evo !
These are actually designed to be used with a permanently mounted generator, but a portable generator will work if you have some place to mount it.
Throw out your current converter. Connect the DC distribution panel directly to the battery bank (via a fuse of course). All connection, shore power, generator power, solar power from the charge controller, house battery and AC out, go to this one unit ! If you have shore power, it uses it. If not, it uses battery/inverter. If that is insufficient it can (optionally) start the generator.
There are probably other manufacturers of the same.
EDIT : Samlex does make a smaller, less expensive, inverter/charger/transfer switch without a separate generator input (so the generator would plug into the exterior shore power cord) but it is only rated at 10A of AC "pass thru" current.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
